pins feature script - could someone check it?
maciekmaciek OS Professional Posts: 35 PRO
Hi,
I made a simple featurescript which makes holes for pins. This code is based on another feature script, but after my modifications it doesn't work.
Can someone look at it? Thanks
https://cad.onshape.com/documents/7885d89fd6ec3627369211b5/w/2607ea11c0a7be49338866ec/e/378d4212adbdd68ac5b3ad02
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 366 image
    edited March 31
    You'll need to increment i, probably at around line 109 or so? Just insert i+=1;
    But you'll also need remove the "MaxNumberOfPicks" : 1 in line 33 to make it work for multiple vertex selections
  • maciekmaciek OS Professional Posts: 35 PRO
    Thanks, it works
