Measurement and Dimensioning Different
Hello, I have a problem. In my drawing, I entered the dimensions as 59 mm. However, in the extruded model, I only see 58.931 mm. Why is that?
See images attatched.
Link to model:
https://cad.onshape.com/documents/eb708340c87658a970869c0f/w/eaba8cb867be91da5a404a1f/e/8ba02576f16200dd70f63d75?renderMode=0&uiState=67ebe5edd8545a6e1c84ecc4
Please share a link to your document with copy access and we'll check it out.
Like MD mentioned, it's not measuring from the same spots. If it were a square this would probably be different. Place a mid point on the arc's and then measure from those.
If you want the dimension in your sketch dimension to read mid points of the arc and not max distance you will need to add a construction line constrained to the mid points of the arcs like I've shown here.
Added in question
Thank you very much! This fixed my problem :)
What was the distance I dimensioned before? The midpoints of the arc are the max distance apart at two opposing arcs or not?
No they are not. unless they are at 45° from each other
See how the 15mm dimension extension line overlaps the arc?
Thanks for your help!
