Extract surface from solid?
vanowmvanowm Member Posts: 128 ✭✭
Is there a way to extract a surface from a solid without using sketch to "outline" it?
For example, get a surface of a cylinder (I used 2 extrudes for solid and surface):
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 381 image
    use an Offset surface feature with offset = 0
