Why isn't this enclose working?
caden_kim517caden_kim517 Member Posts: 9
Here's the document link. The part I'm working on is in the "Outtake Parts" part studio.
https://cad.onshape.com/documents/21d74e98fc4375dac84f2c2a/w/7413bb431169d2d1fdd89053/e/e0a4721fdad310f95b111da9
  • glen_dewsburyglen_dewsbury Member Posts: 1,214 PRO
    Not sure what you're trying to enclose? There are no parts defined as open surfaces that need enclose?
    I also recommend the link you posted be made pubic unless the is some restriction.
    https://cad.onshape.com/help/Content/enclose.htm?Highlight=enclose
  • caden_kim517caden_kim517 Member Posts: 9
    Oh sorry. I fixed the issue and just made the surface a solid with the last fill I used. The original issue was that there was an open part where the surfaces didn’t fully intersect because I forgot to use the guide curves I had set up on one of the surfaces.
