HELP I don't know what I've done wrong!
I used pierce to make sure everything is aligned but it still doesn't work with guides. It works without them, but I don't know what to do to get them to actually work.
S7838293748329237473M2I2S2S2I2O2N | Part Studio 1
  • S1monS1mon Member Posts: 4,125 PRO
    You need to split your sketch 4 and 5 at the vertex. Then you'll have 4 guides, not 2.
  • dariya_ganchevadariya_gancheva Member Posts: 5
    Ok, thank you so much. I am also having problems here with using projected curves as guides:
