Trying to create a mesh of holes across my entire spherical surface
brian_vander_mey
Member Posts: 6 ✭
Hi all,
I've created a half hemisphere with a wall thickness of 0.5mm and I'm trying to perforate it with 0.5mm holes all over.
So far I have used a circular pattern to get a ring around the top, but I can't figure out how to propagate that pattern across the rest of the surface without recreating the approach I used for the first one one-by-one. Where you see "Circular Pattern 2" was my attempt to pattern the previous pattern at a different axis, but I seem to have broken onshape. It "thought" for a very long time until I ultimately deleted that pattern (but it took a long time to delete which is why you still see it).
Thank you in advance for any help.
One question would be why? Is this something that will be formed out of pre-perforated metal? Is this just for rendering purposes? Are you hoping to 3D print it (with which technology?)?
If you absolutely need to model it, what sort of pattern are you imagining? Will it be rows and rows of evenly spaced holes, so that each row has fewer and fewer holes until you end up with a single hole at the apex? Are all the holes supposed to be normal to the surface?
with so many booleans, expect your part to be rather slow to regenerate. that's why S1mons question is relevant: why would you want to make this? can it be done with a render texture or otherwise?
Hi @jelte_steur814 and @S1mon thanks for the responses.
This is sort of a prototype for something I want to do in the future in different shapes. I'm essentially trying to create my own pond baskets, but mine will have more design to them than just rectangular baskets.
So I'll be 3D printing them. Right now, my numbers of 0.5mm are too small, but I am trying to find a way to work out the process without having to place each hole myself. I've even been badly trying to create a FeatureScript which isn't working yet.
Maybe try out @EvanReese 's Attractor Pattern? With a spherical shape, I would use a sector (maybe 1/4?), and then pattern that body.
I'd have to test it out, but I think it can handle removing a shape (say a cylinder) from another solid.
I would experiment with low density, low count patterns to get started, and up those once you have something working.
You may also find this tech tip helpful, since with a sphere, you might be able to come up with a good equation to control the number of instances per row based on the angle.
https://www.onshape.com/en/resource-center/tech-tips/tech-tip-how-to-use-variables-in-patterns-to-vary-features
https://learn.onshape.com/learn/course/variables-and-expressions/expressions/expressions-in-variables?page=1
I modified @Jake_Rosenfeld's Circle Cuts script by writing another script generate a bunch of uniform-ish holes which I plot.
The method is still flawed and doesn't work on all shapes yet. Here's a few shapes I made and tried it on:
I also want to get away from the CSV and have the hole generation parameters defined in the tool. Currently my python allows for inputting hole size and minimum hole distance and then it calculates a sphere of holes. The idea behind this whole approach is that you could broadcast a sphere of "spikes" at any shape all around from the center and you'd get a lot of holes… but it still isn't really what I want.
What I want is all walls/surfaces to be evenly perforated with holes.
Anyway, the hunt continues. I'll keep iterating.
I started learning CAD like 2 days ago, so I spend a lot of my time fumbling around in the dark, so to speak. Pretty slow progress when I don't know how to do almost anything and I have to stop to watch a video every 5 minutes.
@jelte_steur814 for awareness
Here's the link to my code if you're curious. I hope the link works properly, I haven't tried to share this before.
https://cad.onshape.com/documents/f966c7abbef6def8c41b75f2/w/48eeea9989bb0ada76306045/e/04367928eae6c175cc9be729
@S1mon and @jelte_steur814 I want to clarify my intent a little more, my ultimate goal.
I am big into creating bonsai trees, and lately people have started making bonsai pots in interesting shapes using 3D printing. However, pond baskets (see above) are a much better way to grow young bonsai early on; you should wait a while before putting them in a cool bonsai pot for best results. But pond baskets look stupid, and bonsai pots look cool, so I'm trying to find a repeatable method to turn a bonsai pot model into a pond basket hybrid.
I had Sora generate a couple examples of the idea I have for reference purposes.
The challenge for a sphere is quite different than these a little more box or spherical type shapes.
https://extremelearning.com.au/how-to-evenly-distribute-points-on-a-sphere-more-effectively-than-the-canonical-fibonacci-lattice/
there's some math underlying distributing point on a sphere.
I had some time to play around with this challenge though and figured one way of doing it would be to leverage another featurescript called "Geodesic dome" along with some custom FS.
the geodesic dome is quite heavy on the part studio in terms of regeneration time, so I decided to cut the cylinders from another similar sphere that you can edit more easily to create a rim, flat bottom etc.
see this example here:
as @S1mon indicated: making only a part of the bowl and patterning it will make the model a lot faster and lighter, but you'll have to make the part of the bowl obviously correspond to a repeat in the cylinder cut pattern…
You would presumably need a regular-ish sampling of points on the surface. Manually modeling it without custom features would be challenging. With custom features, I can see a few approaches.
For spheres, the geodesic polyhedron approach seems like the most practical. Alternately, use FS to generate points on a Fibonacci spiral (I wrote https://cad.onshape.com/documents/94e43c923c184dc3f4ad7901/v/50c4f9ff33b304c8f61e8f06/e/b1e488dbe0cf1e181062f88b a long time ago, seems to work).
You could also write a custom feature that samples a uniform grid of UV coordinates on a face, using https://cad.onshape.com/FsDoc/library.html#evFaceTangentPlanes-Context-map . Then, if the point is actually on the face, extrude a hole.
