Sheet metal flanges on parts with corner chamfers
cody_glaiel
Member Posts: 5 ✭
I'm learning OnShape and the flange tool behaves differently than how Solidworks would generate it. Any reason why the flange tool basically deletes the chamfer in this situation? It's not that I can't think of a workaround for this using partial flanges and some extrusions, but seems like a lot of extra commands for something that should be more simple unless I'm missing something.
S1mon
Member Posts: 3,745 PRO
Try creating the chamfer with the corner break tool and then use the flange tool. I think you will get the results you want.
1
Use the sheet metal corner break tool, not chamfer.
It isn't as useful as I would like once the chamfer interacts with the bend, but you can also add a chamfer (corner break) and then a bend, depending on what you're trying to do.
The goal was to have the part generate flanges only on the selected line, so it should create a feature that looks like this. This is how Solidworks would handle it. Not sure why the flange feature basically ignores the chamfer feature
Ahhhh I see. Corner break is a sheet metal specific chamfer/filet. Works now, thank you!
