Parts library that provides for each part a simplified and full model version
I'm trying to make a parts library that provides for each part a simplified and full model version(configured via a configuration checkbox), since these parts get used in assemblies with up to 2000 parts and subassemblies so the primitive count is really high and some computers struggle. However I've encountered the problem of ensuring consistency between the two models, since for example in an assembly, when switching between the models, the mates get suppressed.
Is there any way to mantain consistentcy when switching the models(without providing explicit mate connectors the user has to use), any featurescript hack or something?
  • jelte_steur_infojelte_steur_info Member Posts: 655 PRO
    edited April 2025 Answer ✓
    why without the explicit mate connectors? that's definitely the best way.
    otherwise the 'simplification' has to be done in such a way that it will not affect faces that may be used for mates in an assembly. but that may be difficult or impossible and is definitely hard to predict.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,643 PRO
    The explicit mate connector is the best option for sure… But if you have "undisciplined" users, you might be able to use the "assign identity" FS to provide a matching face ID between the two configs (at least my understanding is that it should be able to do this…)
    https://cad.onshape.com/documents/fcf31e8bc171b06037008400/v/7e1b5b2304e2bd6d9223a41a/e/e076332e1669ea9babcaf65b
  • maftei_albert_alexandrumaftei_albert_alexandru Member Posts: 6 EDU
    I agree that the current methods to achieve such simplifcation is extremely flawed, perhaps a feature request to add a feature that enables models to either have a non simplified topology or a feature to simplify a model unless you're adding mates to it is in order.
