How can I use Model file Attribute as Text for Serface Text
eldon_browneldon_brown Member Posts: 50 ✭✭
I would like to automatically emboss my parts with a Part, Rev and/or Branch Number. I can see that I can use/convert text input to an expression, but how can I automatically access the Model Attributes within the expression?
—Eldonb
  • MichaelPascoeMichaelPascoe Member Posts: 2,483 PRO
    edited March 17
    You could the custom feature Get/Set Property.
    Note that when getting properties, onshape does this after the feature tree. This means that custom features can't view these data changes live. So if that property ever changes, you will have to manually open the feature and press the refresh button.
  • eldon_browneldon_brown Member Posts: 50 ✭✭
    Michael, I reviewed your example, and yes it appears that Get/Set Property could be used, but currently I am not knowledgable enough to know how it can be used to set embossed Rev/Branch text info on a part. I will have to do much more research. An example would be useful.
    Thanks,
    —Eldonb
