Thicken surfaces of an import
douwe_siegersma
Member Posts: 5 ✭
I'm working on a design i copied from public.
In the design is an import with many surfaces. I want to thicken these to make them 3D printable.
I can't select the surface to thicken. Is there a way to do this?
Regards,
Douwe
Maybe the new Constrained Surface tool?
Thank you for your quick respons.
I'll try it out.
Well, that kinda works. But only with points, and that way to much work..
Constrained surface with a mesh only works with a tolerance of 3mm resulting in an almost flat surface. 😪
Maybe the mesh is to complex?
You might get more ideas if you can post pics and/or links to the document for inspection
