Counting frame joint edges
graham_lockgraham_lock Member Posts: 265 PRO
Hi,
I'm creating a structure using frames as per the image below:
What would be the best way to count the internal edges of the joints? Each edge will need a right angled bracket which I don't intend to draw but an accurate dynamic count would be useful for BOM purposes.
Any advice appreciated.
Thank you.
  • MichaelPascoeMichaelPascoe Member Posts: 2,827 PRO
    edited April 2025
    How often are you planning on doing this? If very often, it would make since to modify or make a custom feature for it.
    You could modify the original frame cutlist feature so that it counts these for you.
    CADSharp's FeatureScript - Lesson 5 is free, and it shows the basics of how to modify the cutlist feature.
    Or if you don't want to do it yourself you can have a developer like CADSharp do it for you. Let me know if you need this and I can connect you.
    RENDERCAD
  • graham_lockgraham_lock Member Posts: 265 PRO
    Thank you I’ll take a look at that video.
    edited April 2025
    If you don't already know FeatureScript, then I highly recommend starting at lesson 1 and going in order. Each lesson builds on the next so they teach the foundation of what you need to know for the next lesson.
    RENDERCAD
    ok thank you.
