Counting frame joint edges
graham_lockgraham_lock Member Posts: 262 PRO
Hi,
I'm creating a structure using frames as per the image below:
What would be the best way to count the internal edges of the joints? Each edge will need a right angled bracket which I don't intend to draw but an accurate dynamic count would be useful for BOM purposes.
Any advice appreciated.
Thank you.
