Form feature and threaded holes
Wout_Van_GervenWout_Van_Gerven Member Posts: 4 PRO
I'm experimenting a bit with the Form feature in Onshape. I know it's not necessarily intended for this purpose, but I wanted to see if I could use it to create a cutout for a connector in sheet metal.
So far it's working okay, but I'm running into an issue: I can't seem to add threads. They show up in the 3D and 2D drawing, but I can't add a callout for them in 2D.
Has anyone run into this before, or does anyone have any tips on how to work around it?
  • jelte_steur_infojelte_steur_info Member Posts: 606 PRO
    could be a bug: in that case it's best to report it to the support team
