API - Folder Creation, Move Document Functionality
I may just be missing it in the Glassworks API explorer, but does anyone know how to create folders via API, and move documents to different folder locations via API?
Cheers,
-Dirk
  • Caden_ArmstrongCaden_Armstrong Member Posts: 418 PRO
    If you look at /api/documents/{did}
    the document's parentId is the folder id.
    To move to another folder, modify the parentId to a different folder's ID.
    To make a folder, its an undocumented API endpoint, so proceed with caution, use at your own risk, I'm not an Onshape person, etc etc..
    POST /api/folders
    Body:
    {"name":"My new folder","ownerId":"yourCompanyId","ownerType":1,"parentId":"insertparentfolderIdhere"}
  • MichaelPascoeMichaelPascoe Member Posts: 2,822 PRO
    edited April 2025
    This is an old post, but for clarification for future users:
    To actually move that document to the new folder, you will need to use another undocumented endpoint:
    POST : /api/globaltreenodes/folder/{:fid}
    BODY:
    "itemsToMove" : [ { "resourceType" : "document", "id" : <docid> } ] }
    RENDERCAD
