Problem with extruding shape
Max_BarshayMax_Barshay Member Posts: 2
If I try to extrude my sketch, it doesn't work, and OnShape is not telling me why. Please help!
Thanks in advance!
  • matthew_rosete380matthew_rosete380 Member Posts: 31
    Can you try to provide the link to the document that you need help on its hard to tell just from a picture
  • S1monS1mon Member Posts: 3,327 PRO
    The tips need to either have a very slight gap or overlap. Touching at a point produces non-manifold geometry which the Parasolid kernel can’t handle.
  • Ste_WilsonSte_Wilson Member Posts: 459 EDU
    Might be worth doing in two steps. Extrude the outline then extrude remove the teardrop shapes. You could use the same sketch.
