Cookie Cutter - Link Provided
Amy_SarofianAmy_Sarofian Member Posts: 5
In response to David YL Nguyen's suggestion (which I was not able to respond to in the thread) - below is the link to my cookie stamp. The intent is to have the text similar to what I extruded through the bottom. Thank you for your help!
https://cad.onshape.com/documents/1b24eb68953d5e1099ce915f/w/dc4119cd855b87608f96196e/e/785048bbc7653e6d746e91b6
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 153
    Hey @Amy_Sarofian,
    not the cleanest way to do this but since you used the surface text custom feature this was the easiest way for me: https://cad.onshape.com/documents/fc8debd69255a765028dab03/w/9a29b50928adcaa846368167/e/e325f68cdd52820fcfedaa04
    Is this what you are looking for?
