Multi-Part Part Studios no correct answer
petro_zhuk956petro_zhuk956 Member Posts: 5 PRO
I have tried to do everything step by step, but I dont see the right answer. I have 0.712 mass, but there is no such option. Could somebody point me out what to check?
I have double checked everything.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 157
    Hey @petro_zhuk956,
    Looks like you might have too little parts in your Part Studio. Make sure that you select to create new parts instead of adding to existing parts in your Extrude feature where this is required.
  • petro_zhuk956petro_zhuk956 Member Posts: 5 PRO
    Hi @David_YL_Nguyen , I have 7 parts selected. I see 0.718kg but the options from the exercise have 0.556 - 0.684 kg, so my part is heavier.
    @petro_zhuk956,
    probably some material that is wrong or one extrusion/body that is wrong. If you share a public link to your document, people can take a closer look.
  • Ste_WilsonSte_Wilson Member Posts: 494 EDU
    It's not the end of the world :) The important thing is you have practiced the methods and learned how the software works a little more. If you select the wrong one it tells you the correct answer. :)
    Hi all,
    There is the link to the doc https://cad.onshape.com/documents/566594ae9320ff8568f26a47/w/5d18b9dd7e3a85bf4559f4db/e/a6d66a8eeea55b13fd23ec46?renderMode=0&uiState=68131b72e7ee437bac11edd9
    (By the way, I just wanted to point out, that the exercise could have wrong answers.)
  • Lindsay_EarlyLindsay_Early Member, Onshape Employees, Developers Posts: 24
    Hello all. Thank you for bringing this to our attention. Step 4 the revolve thickness should be pointing inward. This wasn't clear in the exercise and I am fixing it now.
