HELP Something went very wrong.
noah_hofer
Member Posts: 8 ✭
So i was making an arc reactor from ironman. and i tried out the mobile... and i tapped something on the feature list called reorder. Then everything got messed up, and part moved and flipped and what not. how do i reverse it??
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 221
@noah_hofer The easiest way would be to restore the Document to before you made that change. Below is a link to a video on restore.
https://www.onshape.com/cad-blog/tech-tip-how-to-easily-restore-a-document-in-onshape
1
