Create query from opPoint
graham_lock
Member Posts: 265 PRO
Hi,
I have the following:
var l = evEdgeTangentLine(context, {
"edge" : edgeToUse1,
"parameter" : p
opPoint(context, id + "vertex3", {
"point" : l.origin
How can I create a query from the point created for use in a sketch constraint or am I going about this the wrong way?
Any help appreciated.
Thank you.
Caden_Armstrong
Member Posts: 348 PRO
Should be able to reference the body you created.
qCreatedBy(id + "vertex3", EntityType.BODY);www.smartbenchsoftware.com --- fs.place --- Renaissance
Custom FeatureScript and Onshape Integrated Applications0
