Thread creator
istvan_woensdregtistvan_woensdregt Member Posts: 4
I use the extra feature thread creator to make inner thread.
I needed a hole with m6 thread.
So i made a 6mm hole and than used the threadcreator. It gave me a pitch of 1 and in the left beam it said. M6 1mm
I printed the file and a normal boot M6 won't fit.
Is this a common problem should I make the hole bigger???
