Color blind
dov_federdov_feder Member Posts: 2
I am just starting to teach myself Onshape. One of the bigger challenges I have is that I am color blind and cannot see the colors of the lines. The black and the dark blue and green all look alike to me. I did some research and don't think I can customize those colors. So if any of you have any suggestions I would greatly appreciate it.
Thank you.
Dov
  • l_p669l_p669 Member Posts: 11
    https://forum.onshape.com/discussion/9817/is-there-a-way-to-personalize-the-user-interface-colors
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 995 PRO
    I’m colorblind also.
    There are no customizations of the colors. It probably wouldn’t even help, to be honest.
    You can try the light mode vs the dark mode. It’s under your name in the top right corner of the screen. It might help sometimes in sketcher.
    The good news is it won’t really affect you much. All the CAD software (actually most software) has the same issue with colorblind users. You’ll be able to learn and design just fine.
