Trouble Filleting surface
colin_king506colin_king506 Member Posts: 44 ✭✭
I am going through the exercise "Introduction to surfacing." Currently on step 13. Everything was designed according to the exercise steps. Why is this doing this?
https://cad.onshape.com/documents/6911b85b1c96ff1a6c7df8d7/w/762174674a63293a692c3f3c/e/97267fe9770e84b4252a3954
Seems the exercises don't match the current version.
Side note:
I have felt that I need to go back and get more experience before continuing.
  • glen_dewsburyglen_dewsbury Member Posts: 1,223 PRO
    Haven't gone through the lesson for some time but it seems like this is what is wanted for end result.
    Using mutual trim is less steps instead of split and delete.
    Also, your original fillet did not operate the way you expected due to an untrimmed face.
  • MDesignMDesign Member Posts: 1,265 PRO
    Everything?
    Also you've chosen delete face, when the tutorial specificed delete part. Can get there with delete face too but you gotta pick an extra face to get to the same end point. You also have to factor in that when these tutorials were made… the tools may have had slightly different behaviors. So there will be some descrepancies. For example the split tool now allows you delete those faces/surfaces within the split feature.
  • colin_king506colin_king506 Member Posts: 44 ✭✭
    Thank you Glen for showing an alternative. That worked.
    ——————————————————————————————-I went back and noticed this: image.png Previous Split worked according to the exercise; That did show up originally - but, the fillet worked once I corrected by choosing the additional face during Delete Face. I digress.I did the Mirror as per the directions; however, it sill still recognized it as 2 "surfaces/ entities" - Face of Loft 1 and Face of Mirror 1. image.png image.png image.png Apologies for the additional 3 screenshots.———————————————————————————————————————————————————————————I admit I did not select the surface of the revolve originally; that would make 3. image.png
    I did not finish the exercise yet though so I am unsure of future errors, but it looks like smooth sailing.
    use delete part per the exercise and it will select whole surfaces vs the delete face that is causing you to select 3 faces.
