Issues with Importing and Exporting Photos and Videos in Onshape
robert_dan
Member Posts: 2 ✭
Hello Onshape Community,
I'm reaching out for some help with an issue I'm experiencing related to importing and exporting photos and videos in Onshape. I'm hoping someone here can offer some guidance or solutions.
Problem with Importing Photos and Videos:
I've been trying to import photos and videos into Onshape to use them as references for my 3D designs. However, I'm encountering several problems:
1. The file formats: I’m not sure which photo and video formats are supported. Sometimes the files don't upload, and I suspect it might be due to format compatibility.
2. File size limitations: Some of my photos and videos are quite large, and I'm worried they might be exceeding the upload limits. Is there a specific size limit for files that I should be aware of?
3. Quality issues: When the photos and videos do upload, the quality sometimes seems reduced. I need high-resolution images and clear videos for accurate references.
Problem with Exporting Photos and Videos:
Once my designs are complete, I like to export images and video walkthroughs of the designs to share with clients and team members. Here are the issues I’m facing:
1. Export quality: The exported images and videos often don’t look as good as they do in Onshape. They appear pixelated or lose detail.
2. Export formats: Similar to the import issue, I’m unsure which formats are best for maintaining high quality when exporting. What are the recommended settings?
3. File management: Sometimes, managing the exported files becomes a hassle due to their size or format. Any tips on how to efficiently manage these files?
Additional Concerns:
1. Are there any plugins or add-ons that might help with these issues?
2. Any general tips on working with photos and videos in Onshape to ensure the best quality and compatibility?
I would greatly appreciate any advice or tips from those who have experience dealing with photos and videos in Onshape. Thank you in advance for your help🙂!
Best regards,
Totally get where you're coming from — working with images and videos in Onshape can be kinda tricky. I’ve run into a few of these issues myself, so here’s what I’ve learned:
Import stuff:
Export stuff:
ProjectName_V1_topview.png) saves a ton of headaches later.Extras:
Hope some of that helps! Let me know how it goes or if you find any good tricks. 😊
Cheers!
I am also encountering this issue! Please help me.
