Not fully defined?
walter_fordwalter_ford Member Posts: 4
My uneven sided hexagon has all sides and angles defined but is still not fully defined in the right plane. What am I missing?
  • MDesignMDesign Member Posts: 1,016 ✭✭✭
    You probably haven't told onshape where you want the hexagon located relative to the origin or 2 planes or other geometry in the model.
  • rick_randallrick_randall Member Posts: 402 ✭✭✭
    MDesign is correct, and this is probably one of the most reoccurring questions about sketching that trips up the novice user. You have got to "anchor" your geometry to the origin (it's the only reference point that is fixed in 3d space). Do this with constraints, or dimensions. The good news is that it can be done at any time, but I find it's just easier to do it from the start. Try to make this a habit (this is good practice).
    P.S. you don't have to fully constrain sketches in order to make parts - but if they aren't, it can cause issues if you come back later to do edits to the model. Good luck
  • walter_fordwalter_ford Member Posts: 4
    Can anyone make me a hexagon starting in top plane origin point with alternating side lengths of 27mm and 132mm that is fully defined?
  • glen_dewsburyglen_dewsbury Member Posts: 1,120 PRO
    edited May 5
    Is this what you're looking for?
    https://cad.onshape.com/documents/dce3c5f6c9717f40901277de/w/fcaab14d969087547cdfbe2a/e/ca75bc36994616f9e9aab667
