Make part with conditional transparency?
vanowmvanowm Member Posts: 30
Hello.
Is there a way make a part transparent based on configuration (aka add a checkbox to make a part transparent or not)? (via appearance or transparency feature)
Thank you.
  • Alex_KempenAlex_Kempen Member Posts: 250 EDU
    edited May 3
    FeatureScript's setProperty with PropertyType.COLOR can set both the RGB and alpha (opacity) of a part, although that workflow will of course be for part studios only.
  • EvanReeseEvanReese Member, Mentor Posts: 2,349 ✭✭✭✭✭
    Here's an example using my Part Color feature.
    https://cad.onshape.com/documents/27db832908e005a57fa4a4b8/w/aba6a8a54c161e503412d8f4/e/8851a175a2ca12aff6660282
    Independent Onshape Consultant
  • vanowmvanowm Member Posts: 30
    Since this was asked in drawing section of the forum, not featurescript section, would you please provide little more details how to achieve this?
    You don't need to know featurescript for my solution. Just use the Part Color feature and configure the alpha value.
