Problems doing Exercise 2 of Introduction to surfacing, step 4
colin_king506colin_king506 Member Posts: 44 ✭✭
I have 2 problems right out of the gate:
and
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 846 PRO
    Hard to know exactly what the problem is from the pictures, but sometimes Onshape will assume a constraint while you're sketching that you might miss. Try showing all constraints to see if there is anything extra in there. As for the Pierce, you want to select the virtual sharp of the conic, and a line in Sketch 1.
    Here is the functioning sketch:
    https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/0a390287ade390e01add5d8b
  • colin_king506colin_king506 Member Posts: 44 ✭✭
    I figured it out. Thanks.
