Problems doing Exercise 2 of Introduction to surfacing, step 4
colin_king506
Member Posts: 45 ✭✭
I have 2 problems right out of the gate:
and
Matt_Shields
Member, Onshape Employees Posts: 916 PRO
Hard to know exactly what the problem is from the pictures, but sometimes Onshape will assume a constraint while you're sketching that you might miss. Try showing all constraints to see if there is anything extra in there. As for the Pierce, you want to select the virtual sharp of the conic, and a line in Sketch 1.
Here is the functioning sketch:
https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/0a390287ade390e01add5d8b0
I figured it out. Thanks.
