FeatureScript's setProperty with PropertyType.COLOR can set both the RGB and alpha (opacity) of a part, although that workflow will of course be for part studios only.
Here's an example using my Part Color feature.
https://cad.onshape.com/documents/27db832908e005a57fa4a4b8/w/aba6a8a54c161e503412d8f4/e/8851a175a2ca12aff6660282
Since this was asked in drawing section of the forum, not featurescript section, would you please provide little more details how to achieve this?
https://greasyfork.org/en/scripts/565664-onshape-auto-login
You don't need to know featurescript for my solution. Just use the Part Color feature and configure the alpha value.
@EvanReese thank you, this is exactly what I was looking for. Took me a minute to figure why it didn't work when I added my part to the list…evidently I had to add a "feature" to the list instead.
Likely because you had already manually assigned a color to the part in question. Once it's been done manually it overrides changes made by a feature unless you go to part properties and click the blue button to reset them. Selecting a feature actually chooses the faces associated with that feature.
