How to make Teardrop shape?
Evan_DickinsonEvan_Dickinson Member Posts: 2
Hello all,
Currently, I have this design by sketching an ellispe shape and then extruding it, I've been tinkering with on shape for the past three hours, and can't figure out how to generate a "teardrop" shape from this - I want both of the poles to collaspe to a point as shown, along the length axis, however, I want the shape from above and below t look like this:
My next best guess is to revolve this surface as well after I make the lines black, and then somehow take the intersection of them (I believe that yeilds the desiired shape with appropriate boundaries???)
ANY advice would be appreciated
  • EvanReeseEvanReese Member, Mentor Posts: 2,867 PRO
    edited May 2025
    Model half of it. I used arcs with tangent constraints between them and made the center of the bottom one coincident with the origin.
    https://cad.onshape.com/documents/957683e3522914fc26f8eb02/w/92fb3b575ae101446a80fa00/e/9a0b21b07db1b63629cf4fdc
  • MDesignMDesign Member Posts: 1,334 PRO
    Use Evan's method but you will need to use a spline or more arcs in your sketch to get closer to a tear drop shape.
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    edited May 2025
    I think a teardrop is somewhere between the last two. But the second one made me chuckle because it looks like the snot sucker I used when my son was a baby.
    https://cad.onshape.com/documents/46e66b4c68bcf60a092d25fe/w/b0fc951995746a5b507fe2b2/e/16ec756510715f52c8a594ef
    LOL…it is allergy season.
