Sheet metal part turns into multiple parts.
eng_ixiwatereng_ixiwater Member Posts: 1 ✭✭
I have a simple sheet metal part made of flanges and hems. When I add a certain flange, the hem to which it is added along with the newly added flange suddenly changes into a new part. I cannot see how I can prevent this from happening. Everything should remain one part. Any help will me much appreciated.
  • martin_kopplowmartin_kopplow Member Posts: 1,078 PRO
    We'd probably have to see the part in order to find out what is going on.
  • cora_chen990cora_chen990 Member Posts: 2
    Check connectors and connections, use Merge or Add functionality:
    In your CAD software, make sure you are adding the flange to the same part file. Sometimes the setup can cause the new features to be treated as separate components.
