Frames and configured sketches
graham_lockgraham_lock Member Posts: 265 PRO
Hi,
I have a configured sketch which I am applying to multiple frames. It's a simple rectangle with configured height and width.
Is there a way to apply the configured sketch to multiple frames simultaneously or do I need to edit each frame individually?
Or is there a better way to set the frame sketch profiles using configurations?
Thank you.
  • graham_lockgraham_lock Member Posts: 265 PRO
    I had an error applying the Part Studio configuration variables to the sketch parameters - now working as expected where all frames update with a change in config values.
