Custom Feature: Heat Set Insert (Threaded inserts for 3D Printed Parts)
brett_jaeger168brett_jaeger168 Member Posts: 4
I wanted to learn FeatureScript, so I created a new custom feature to place cavities for heat set inserts into 3d Printed parts quickly and easily. I have been really happy with it and have found that it really speeds up my designs, so I wanted to share it out!
Right now, it includes dimensions for 3 different brands of inserts: McMaster, CNC Kitchen, and Ktehloy on Amazon.
The featurescript creates a cavity that is the correct diameter for the insert selected from the drop down menu and the correct depth to allow the melted plastic to have somewhere to go when the insert melted in.
My preferred workflow is to use the normal Hole tool to make tapped holes and set the location of the heat set insert using mate connectors in the Heat Set Insert tool. Let me know if you want any features added to make it even better!
  • t_e652t_e652 Member Posts: 2
    Amazing!
    Don't know yet how to fork it from your file, but I created a copy and added a Lookup Table for Ruthex Inserts, which are very popular in europe/germany:
  • jason_1jason_1 Member Posts: 28 PRO
    edited May 15
    Wow! I made this same feature a few months ago and was just getting ready to officially "publish" it (once I made an icon and pdf and met all other requirements). I'm going to take a look at how you did it and see how close we were…
    the copper coloring of the faces is a great bonus!
  • EvanReeseEvanReese Member, Mentor Posts: 2,371 ✭✭✭✭✭
    Awesome! I've made something similar for internal user before, but it's great to have a general purpose tool. thanks for sharing it!
  • MichaelPascoeMichaelPascoe Member Posts: 2,294 PRO
    Noice! 😎
