Broken in-context references
graham_lockgraham_lock Member Posts: 256 PRO
Hi,
I'm working on a copy of a sketch which originally had some in-context references.
In the current version those references are not required.
The copied sketch shows a broken in-context references error.
It doesn't appear to be causing any problems but I can't see how to delete them to clean things up?
The error appears like this:
If I hover over the error in the feature tree then two lines are also highlighted in magenta but I couldn't capture the image while hovering.
Any help appreciated.
Thank you.
  • martin_kopplowmartin_kopplow Member Posts: 1,001 PRO
    edited May 16
    Open the sketch, select the broken reference (that little square flag with the leader that clings to the sketch item) right in the sketch and hit delete.
  • graham_lockgraham_lock Member Posts: 256 PRO
    Thank you but I don't have those flags?
