Mirror constraint in a simulation assembly
sam_dickinson82sam_dickinson82 Member Posts: 2 PRO
Is there such a thing as a "mirror constraint" for the Onshape Simulation environment?
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 365 image
    Yes, you can use a planar mate for this. Just add a dummy instance - e.g. make an offset surface and insert in to the assembly, fix it, and add the planar mate.
