Loft Error - Cannot use faces or regions with inner loops as profiles.
windsorseanwindsorsean Member Posts: 4
Newbie here so apologies in advance if I'm doing something dumb…
I'm trying what I thought was a simple loft between two sketches. One is a copy of the other in an offset plain just a little bit smaller, so I'd like the faces to connect to each other to make sloping walls. This is designed to fit the seat back of my car to eventually become a mount.
The loft is complaining about "inner loops" but I need curved surfaces. What am I doing wrong?
Version link: https://cad.onshape.com/documents/1fa9c90982ccc08dc8105219/v/df238c9e9f4ee22d4ee4d29b/e/8b3ef6668190d43dfa326c2f?renderMode=0&uiState=682b535a9e441e7fcc346441
For reference only, I'd like it to look like the image below (I just created a simple extrude for illustration purposes) but end the loft lined up with the other face.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 905 PRO
    As the title of your post says, you cannot use faces or regions with inner loops as profiles. A thin loft work work pretty well in this case. Or make a solid with the outer loops then a remove with the inner loops.
    Screenshot 2025-05-19 at 1.02.08 PM.png Screenshot 2025-05-19 at 1.02.52 PM.png
