How to determine if an edge is a line or an arc
gaetan_vincentgaetan_vincent Member Posts: 4
Ok, so I am new to FS, but not new to programming. So far I am really loving and praising onShape and even praising it, but I have now been struggling with this for days, searching the forums and searching google for examples on how to do this. I have tried many different ways to accomplish this from the few similar examples I have been able to find, and have not yet been able to figure out what I assumed to be a simple task.
All I am trying to do is to let the user select a face ( either from a sketch or an extrusion), retrieve all the edges that make up this face, and determine if each edge is a line or an arc. Once I have accomplished that, I will try to extract the start and end points of those edged and the center point if it is an arc, from there try to do things like offsets and more. But one step at a time.
With the following code I know that I am retrieving the edges using qLoopEdges because the for-loop does loop through the number of items that make up the face I have selected. However, I cannot find how to manipulate those edges once I do have them. Using canBeCircle and canBeLine was my last attempt out of 20-30 other trials to get this to work.
FeatureScript 2656;
import(path : "onshape/std/common.fs", version : "2656.0");
annotation { "Feature Type Name" : "Looper", "Feature Type Description" : "" }
export const looper = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Face", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
definition.face is Query;
    var edges = qLoopEdges(definition.face);
    var queryArray = evaluateQuery(context, edges);
    for ( var i = 0  ; i < size(queryArray); i+=1 )
        if (canBeLine( queryArray[i]))
            println("Edge " ~ toString(i+1) ~ " is a line.");
        else if(canBeCircle(queryArray[i]))
            println("Edge " ~ toString(i+1) ~ " is an arc.");
        else
            println("Edge " ~ toString(i+1) ~ ": is unknown.");
Any input is greatly appreciated
Gaetan
  • MichaelPascoeMichaelPascoe Member Posts: 2,412 PRO
    edited May 27 Answer ✓
    qGeometry should do it.
    https://cad.onshape.com/FsDoc/library.html#qGeometry-Query-GeometryType...
    Also, here is another way to check if its an arc:
        var diameter = undefined;
        try silent
            diameter = evCurveDefinition(context, { "edge" : queryArray[i] }).radius;
        var isArc = diameter! = undefined;
  • jelte_steur814jelte_steur814 Member Posts: 495 PRO
    edited May 27
    unless you're trying to do something specific with the offsets, there may be a quicker solution.
    import topologyUtils.fs and use getThinWallRegions function.
    it's how onshape's 'thin' tabs operate in e.g. extrude and revolve.
    If you 'go to definition' or look at onshapes native features, you'll be able to figure out what keys in the definition map to use.
    good luck!
  • gaetan_vincentgaetan_vincent Member Posts: 4
    Thank you @MichealPascoe!
    qGeometry does not really work as I need all edges of the face. As of now I was only using lines and circles/arcs to create my faces, but eventually I could see those faces becoming more complex. evCurveDefinition, however, definitely does the trick along with canBeLine and canBeCircle to do the identification.
    @jelte_steur814
    Thanks for that info, sounds interesting , but also a little too advance for me for now, but I will definitely be looking into it further down the line. I have realized that I didn't really understand how maps worked in FS and which was also causing my confusion in the use most of the functions.
    Since I work better with examples
        for (var i = 0; i < size(queryArray); i += 1)
            var curvetype = evCurveDefinition(context, {
                    "edge" : queryArray[i] });
            if (canBeLine(curvetype))
            else if (canBeCircle(curvetype))
            else if (canBeEllipse(curvetype))
