Flip Arc?
calvin_selin
Member Posts: 6 EDU
Is there a way to flip an arc when you regenerate your part studio and the arc comes out backwards?
eric_pesty
Member, pcbaevp Posts: 2,467 PRO
To answer your question, no there is no "quick" way to fix that in a sketch.
This is one of the reasons why (as a general rule, there are exceptions obviously…) it's better to leave sharp corners in sketches and use fillet features after the fact.
2 -
MDesign
Member Posts: 1,258 PRO
Either mirror the entities and delete the old ones and reconstrain. or do this…
which requires deleting 2 constraints and moving the center point of the arc.
1
Would be a good idea to add an image to your question since the arc should not change. 🤔
for example, if I have an arc with a fixed diameter and is tangent to two lines, when I regenerate it, It will flip.
Would be useful to add a link to your document, That will someone to copy and interpret the issue or you.
for example, this convex arc looks like this.
When I Angle the are past 0 degrees, the arc goes all the way around, like this.
I was wondering if there was a tool (other than manually deleting constraints and re constraining them) to flip the arc to make it like this:
these all have the same constraints and dimensions, but are different.
