Add a additional part to to a context
svenolov_nystrom
OS Professional Posts: 84 PRO
I have a made a context Hydraulic hose when I go to the assembly I get a question to add parts and go to assembly
Wen I update the context and add another part (hose) I cant add it to the context the menu is not there
This is a bug or do I miss something
404 007.00 000 BBU 141 DRIVE UNIT | 404 007.00 800 Drive unit BBU 141
nick_papageorge_dayjob
Member, csevp Posts: 1,034 PRO
It's not a bug, it's the way it's designed. The very first time you make a context and are in the part studio, it will have the option to add the new parts to the asm. After that, if you go back and forth between the asm and the part studio, you will need to add any new parts manually.
https://cad.onshape.com/documents/579c0914cb3bc1b9ec2db1f7/w/c97c2de6fe222b1456d31222/e/fd6988ce5864f10004365aa5
I think I have a workaround It is ok
It can be solved if you insert the added part into the assembly
Right click on the part and chose in the menu add mate connector for the context part
It is far fetched but it works
