how do i export models at the correct size
so I'm new to onshape and trying to create a model to 3d print and every time i try to export my model and open it in the slicer its tiny and i cant find out why
I'm using inches to model and Sovol Cura for my slicer
if you need to know any more details let me know and any help would be greatly appreciated
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,130 PRO
    Are you exporting as stl? If so, stl does not track units, and your slicer probably thinks it’s in mm. You can scale the parts in the slicer by 25.4. That converts in to mm.
    Another option is to export as step. Step format does keep track of units. Not all slicers accept step, however. I’d try this first and if it works, always use step going forward.
