Groove missing in the drawing studio
ProApeProApe Member Posts: 130
edited June 6 in Using Onshape
Hello,
I would like to create a drawing for export as dxf to generate a code that controls my CNC milling machine. Unfortunately the groove in the middle part is missing.
While I place the drawing it is there (see photo) but after it is placed the groove is gone (see screenshot).
Why is that and how can I get the groove into the drawing? I need it for the GCode.
Kind regards
ProApe
https://cad.onshape.com/documents/c8853fd9fa95b07df5358ed7/w/2f932f71df653bb9b51e6645/e/9116877f9eff1ce8d932ce5b
  • ProApeProApe Member Posts: 130
    edited June 8
    In order to have the groove in the drawing, I have to insert this middle part separately and place it over the existing one with all the parts.
    I don't understand why this is the case.
    And I find it strange that it is present during insertion, but disappears after insertion!
  • edited June 10
    This content has been removed.
    Quel est le rapport avec de l'argent?
    D'ailleurs: "…ça sent", pas "ça sens"!
    si je peux me permettre
  • jelte_steur814jelte_steur814 Member Posts: 491 PRO
    I guess you figured it out because in the linked document it's visible?
    did you know you could export a flat face from the part studio directly to dxf? with some cheating in the model, this may be easier than going trough a drawing… (depending on what/how you're milling)
    edited June 11
    "I guess you figured it out because in the linked document it's visible?"
    No, I had to superpose the part with the groove on the whole geometry; when I inserted the whole geometry the groove was missing! See my message from June 8th.
    "did you know you could export a flat face from the part studio directly to dxf?"
    No, I didn't
    edited June 11
    How can I delete my message in French in response to an unrelated message that has been deleted, both from June 10th?
    It is sub-optimal that the messages are not either numbered or keep the time, and not just the date. This would make it easier to reference a specific message.
