Split Tabs Inside Onshape
marius_hanumarius_hanu Member Posts: 2 EDU
It would be useful to have a way to open two tabs side-by-side directly within onshape. Using two separate windows is not that practical since the ui is duplicated and compressed, so there remains extremely little viewing/working space. Split tabs would also be useful for comparative design, and i think it would be more convenient and easier to work with rather than using the already existing in-context tools in some situations
  • edited June 2025
    This content has been removed.
  • This content has been removed.
  • glen_dewsburyglen_dewsbury Member Posts: 1,266 PRO
    A second monitor is really handy. Run another OS on second screen and display any tab you like.
    Highly recommended when going through the learning center lessons.
