Problems with loft and thickening
tyler_geiger873
Member Posts: 11 ✭
so I'm trying to create a under water drone and this is my first like real project in onshape and im struggling the loft if you look in the first image below the loft dose this weird thing were it doesn't stay smooth it dose this weird artifact any help is greatly appreciated
also when I type to thicken it, I can only thicken it so much like 0.9mm or it doesn't work and sometimes it doesn't work at all and says 'failed to thicken" any help is very much appreciated
A link to a public doc often gets more people helping :)
A few notes:
You can evaluate the curvature of your surface with the Curvature Color Map tool. You can set it to minimum radius, and play with the color sliders to find the area of least curvature. When you mouse over the surface it shows the radius of curvature at that point. The smallest number here is the number at which your thicken will fail.
Can't thicken it where there are tight wrinkles in the surface as it cuases an overlapping geometry situation. Any reason why you have so many profiles? Usually when there's an "endcap" sorta situation with lofts it might be easier/better to do that as a separate feature. Depending on the desired shape you can do a loft or a fill for the ends.
here the link to the model, I frogot to add it https://cad.onshape.com/documents/2e559d51465c960ecc2071ec/w/18a8db6e194f3f7a1ee57f69/e/f8944e8860685539cc359774?renderMode=0&uiState=68499c0738d9bc7021258d38
