How Do I Make A Wolf In Onshape
raihan_riaz855raihan_riaz855 Member Posts: 3
How Do I Make A Wolf In Onshape, I need help
  • afalzate13afalzate13 Member Posts: 46 PRO
    You make it with practice :)
  • _anton_anton Member, Onshape Employees Posts: 462
    Hmm, depends. Does it have to be a live wolf? How are you manufacturing it?
  • MDesignMDesign Member Posts: 911 ✭✭✭
    Download one and import it.
  • jelte_steur814jelte_steur814 Member Posts: 493 PRO
    edited June 12
  • yip_cmyip_cm Member Posts: 22
    May I know how to break down into each individual parts with adjustable heights?
    https://cad.onshape.com/documents/f2e3659b4d875f467bab794d/w/7dc9b9d6f4b13ba06fc6c621/e/834fe8965cdc6c21c75e64ad
  • MichaelPascoeMichaelPascoe Member Posts: 2,398 PRO
    Not sure why this post hasn't been directed to the learning center yet, but the Learning Pathways are the best way to learn how to do advanced surfacing. You will need advanced surfacing skills in order to do organic shapes like wolves.
    @yip_cm To have adjustable parts, you will need to configure the part. You can also learn how to do this from the Learning Pathways.
  • martin_kopplowmartin_kopplow Member Posts: 831 PRO
    edited June 13
    And keep in mind, everybody, that wolves can only be created at full moon. ;0)
    edited June 13
    Try to read about variables and configurations. There is a way to model a part (like the cylindrical ones) and the create different configurations for e.g. their lenght, so cou can individually select that in your assembly. → Learning Center
    … and also, as a hint, you might get more help, if you asked that is an appropriately named discussion, not under "How to create a wolf?".
