Can't select an Extrude Remove entity for a Linear Pattern
BurgerMannheimBurgerMannheim Member Posts: 2
I'm trying to create a pattern of holes vertically using Linear Pattern. I created a Remove Extrude before trying to create the Linear Pattern but I can't select that Remove Extrude as an entity to pattern. Does anyone have any insight?
Thank you.
