Custom Feature: Heat Set Insert (Threaded inserts for 3D Printed Parts)
brett_jaeger168brett_jaeger168 Member Posts: 5 ✭✭
I wanted to learn FeatureScript, so I created a new custom feature to place cavities for heat set inserts into 3d Printed parts quickly and easily. I have been really happy with it and have found that it really speeds up my designs, so I wanted to share it out!
Right now, it includes dimensions for 3 different brands of inserts: McMaster, CNC Kitchen, and Ktehloy on Amazon.
The featurescript creates a cavity that is the correct diameter for the insert selected from the drop down menu and the correct depth to allow the melted plastic to have somewhere to go when the insert melted in.
My preferred workflow is to use the normal Hole tool to make tapped holes and set the location of the heat set insert using mate connectors in the Heat Set Insert tool. Let me know if you want any features added to make it even better!
  • t_e652t_e652 Member Posts: 2
    Amazing!
    Don't know yet how to fork it from your file, but I created a copy and added a Lookup Table for Ruthex Inserts, which are very popular in europe/germany:
  • jason_1jason_1 Member Posts: 29 PRO
    edited May 2025
    Wow! I made this same feature a few months ago and was just getting ready to officially "publish" it (once I made an icon and pdf and met all other requirements). I'm going to take a look at how you did it and see how close we were…
    the copper coloring of the faces is a great bonus!
  • EvanReeseEvanReese Member, Mentor Posts: 2,778 PRO
    Awesome! I've made something similar for internal user before, but it's great to have a general purpose tool. thanks for sharing it!
  • MichaelPascoeMichaelPascoe Member Posts: 2,757 PRO
    Noice! 😎
  • brett_jaeger168brett_jaeger168 Member Posts: 5 ✭✭
    Thanks @t_e652 ! I have added the Ruthex info into the official featurescript! You building that lookup table for me saved me a lot of time!
  • rbotsrbots Member Posts: 2
    Perfect FeatureScript - this saved me thousands of hours. You're the best!
  • florian_foellflorian_foell Member Posts: 2 EDU
    @brett_jaeger168 Very cool FeatureScript, almost what I was looking for. "I" (claude.ai and I) modified the script to be able to add chamfers and screw holes. I don't know how to fork off your script so I made a new one. I give full credit to you and @t_e652 at the start of the code and the guide. I hope that works out for you, feel free to use anything useful from "my" code.
    Link to my script: https://cad.onshape.com/documents/9162edf9d20fe06a0aadc971/w/91214d4ca77def1b802fe98b/e/9f380e83ff4145f543e11fdf
  • joshtargojoshtargo Member Posts: 464 EDU
    could it be modified to also add an insert to the first hole so it can be replicated in the assembly?
    Interesting thought and I can see some of the convenience here. I'd personally rather have a single source model in a part library though and only add that to assemblies. If the feature adds it, then it's equivalent to deriving it in. Onshape is going to see them as different parts every time you use it, or if you used the feature in 2 different places. You BoMs will get weird. Maybe that's not important for what you're working on and the convenience matters more, in which case, it's totally doable.
  • damian_crosbydamian_crosby Member Posts: 9
    Great script, I would suggest you change your merge scope filter to mirror the one used for the hole feature:
    annotation { "Name" : "Merge Scope", "Filter" : (EntityType.BODY && BodyType.SOLID && ModifiableEntityOnly.YES && AllowMeshGeometry.YES) }
    definition.mergeScope is Query;
    That way we can merge with meshes, great for putting heat set inserts on laser scanned parts for mounting.
    Thanks for the suggestion Damian! I made the change.
