copy design using api
abdallah_mashalyabdallah_mashaly Member Posts: 7
i have a public design for example this one
https://cad.onshape.com/documents/fc8af75b1e15f82459f28f6f/w/431848f670c2fa7a12ebc577/e/b9af0e7afeae426fd3426fdd
im trying to copy it using the api
method = POST
path = f"/api/documents/d/{source_did}/w/{source_wid}/copy"    body = {        "newName": new_doc_name,        "isPublic": is_public    }
i get document not found , but when i use the same ids , but with a different endpoint to get the document details:
method= GET
path = f"/api/documents/{doc_id}"
i get the document details
am i using the wrong endpoint or is there another method?
i know i can do this from the viewer by simply pressing the button in the image , but is there a way to do it using the api??
