New Feature: Poly-Mate Connectors
Derek_Van_Allen_BD
Member Posts: 608 PRO
My drafting team have run into situations where they've needed to define multiple explicit mate connectors in one operation for ease of organization and later reference in features. Naturally after searching for an existing tool that does multiple connectors in one operation and not finding one they requested that I develop a quality of life script that does this multi mate connector operation.
Introducing: Multi-Mate Connectors wait that's taken
Introducing: Poly-Mate Connectors
It places multiple explicit mate connectors in one go, so if you need to re-reference them multiple times it's easy to hide and show them all at once by changing the visibility of the feature itself. This makes it simple to drag select the whole window to grab all the explicit mate connectors in frame to quick select locations for hole operations or things not easily defined by sketch geometry.
wow! very cool! i also did't know the the polyhedra FS!
Someone on the Onshape discord clued me on to the polyhedra script. I'm definitely gonna get some mileage out of it for laser cutting projects.
Derek Van Allen | Engineering Consultant | MeddlerHaven't used this one but I was aware of another one:
https://cad.onshape.com/documents/2c40f522f1b5a02f6ce9ce01/v/585e4b002529cb792b0466cf/e/ff4f6157c94f693e713e91d3
That's not even the other one I was using before, that's a step up from what I was originally working with but the polyhedron script I used in the demo of this feature takes the cake for me for sheer absurd volume of options. It was apparently based off the mathematic structures on this website.
I haven't exhaustively checked that they're all in the script but it certainly looks like the author took someone's joke of "Oh, you're a fan of shapes? Name every shape" as a personal attack and delivered.
Derek Van Allen | Engineering Consultant | MeddlerThis is awesome! Can you add the ability to select an owner body? Excited to add this to my workflow.
EDIT: I gave it a shot myself.
I run into an error when the owner for the mate connectors is not a body such as a sketch or curve.
V2 added support for sketch entities and curves. Your version doesn't have those bodies allowed in the owner body filter.
Derek Van Allen | Engineering Consultant | MeddlerOof, rookie mistake. 😂 Thanks!
Latest update brings baked in Query Variable functionality to group the collective of the selected mate connectors for easy dynamic selection in other features. Combine this with my new Amalgamate feature and you can quickly seed and generate complex and robust geometry in far fewer steps than before.
Derek Van Allen | Engineering Consultant | MeddlerNew update brings more mate connector stability courtesy of some contributions from @MichaelPascoe. Moving or reassigning mate connectors should now maintain references in later features and assemblies due to this improvement. We only had to sacrifice the stability of any documents that were referencing this feature prior to now. If you have a document from version 3 or before, you might find yourself needing to reapply those features if you update. Not universally though, I only found a few cases that actually broke.
Derek Van Allen | Engineering Consultant | Meddler2 more new updates, now sketch vertices are supported as an input which should allow you to do more power select stuff and window drag stuff than before, as well as allowing query reordering which should make it easier to shuffle instances in cases where you might have mistakenly applied your mates in a different order than other configurations in something like a standard component library driven from configured and versioned import geometry and your assembly mates are shifting around on you when you change part configurations.
