/documents endpoint
Ace_Caoile
Member Posts: 10 PRO
in Drawings
Is there a way to get all the documents inside a folder using this endpoint or maybe /documents/search
I know
https://cad.onshape.com/api/globaltreenodes/folder/${folderId}
allows users to get all the contents of a folder but I'm trying to avoid using this unofficial endpoint if possible. Thanks in advance
The /documents endpoint has the parentId as a possible url parameter. Which is the folder id.
https://cad.onshape.com/glassworks/explorer/#/Document/getDocuments
But in a quick test, it looks like it isn't working. The owner property also isn't working…
You should open a ticket with api support. According to the documentation, what you are trying to do should be possible.
Hi Caden… I did try using the parentId but as you said, it seems to not work at the moment.. So there isn't really a way to extract these contents using /documents or /documents/search? Because I'm thinking that I may just be constructing my parameters or payload incorrectly…thanks
In the past I have done this with the global tree nodes endpoint, which is obviously not recommended.
I just tested the endpoint as documented, and yeah - something isn't working. But according to the documentation it should be. So I would suggest you email api support.
