How do I solve this inverse kinematics issue
ahsan_ahmed
Member Posts: 2 EDU
I have 2 rotatable arms, and when I try to mate them with a revolute, onshape can't solve the assembly and caues other mates to break:
Once mated:
Is there a way I can get the assembly to solve with inverse kinematics?
https://cad.onshape.com/documents/044489cf90bf8bba13046e46/w/f005f843b6ad9e5f2bf02ea4/e/e853c1892c9a9c5eecee8049
eric_pesty
Member, pcbaevp Posts: 2,665 PRO
I'm guessing there the links already have mates that constrain them on the Z direction and there is mis-match somewhere (could even just be a rounding error in the math).
Change that revolute mate to a cylindrical mate to avoid this.
2
Agree that a cylindrical mate is the way to go. Otherwise you have two different mates telling that part exactly where it should go, and even if they "say the same thing" software tolerance limits can cause failures. With cylindrical, only 1 mate is defining the z position of the link.
