How can I make this panel match this curvature?
cooper_wiemkencooper_wiemken Member Posts: 2
https://cad.onshape.com/documents/c2d08122b7071e78ddef2ecc/w/c85ee399eb656c77a356c89b/e/6099882c0de00cccbf126294?renderMode=0&uiState=6854bf46da6bb33b3c0baa01
  • martin_kopplowmartin_kopplow Member Posts: 1,176 PRO
    You will need a possibly 'overbuilt' reference face, created off profile and guide curves in the U and V direction of this object. See "Loft" in the learning section for further information. Then, you can project your sketch curve onto that surface and get the desired 3D curves.
  • MDesignMDesign Member Posts: 1,285 PRO
    edited June 2025
    Constrained surface makes this a freak'n breeze. Man I wish I had that tool 9 months ago. Wasn't sure what your design intent was. I just made a piece that was offset down a smidge from the top and inset into the opening.
    No need for profiles, guide curves, tangencies, end conditions, paths, etc.
    Note: learning the surfacing tools does help with this sort of thing to understand what is happening. and making edits easier.
  • S1monS1mon Member Posts: 3,891 PRO
